My 95 impala ss gears are sticking.
1995 CHEVROLET IMPALA
DMILL828
My 95 impala ss is having trouble shifting from gear to gear. It sounds like the gears are getting stuck. I usually put mid grade or premium gas in it and this time I used regualr on accident, couold that be the problem and if so how do i fix it?
It is a 95 chevorlet impala ss andit has 93,000 miles on it and it has a V8 port fuel injection engine
Sep 23, 2007 at 4:40 PM
J CAT
  • 5 POSTS
[quote:5fd4f326c6="dmill828"]My 95 impala ss is having trouble shifting from gear to gear. It sounds like the gears are getting stuck. I usually put mid grade or premium gas in it and this time I used regualr on accident, couold that be the problem and if so how do i fix it?
It is a 95 chevorlet impala ss andit has 93,000 miles on it and it has a V8 port fuel injection engine[/quote:5fd4f326c6]
It is not recommended to use higher than 89 octane as this will carbon up the engine and damage other components.this is stock as built by GM 94-96 years. I would drop transmission pan and inspect filter and pan bottom for excessive dirt/contaiminates low pressures in trans . will cause poor upshift
Oct 13, 2007 at 8:54 PM
