clutch or transmission
CHEVROLET IMPALA
NOAHTHEPIMP
  • 5 POSTS
according to many other problems my car is having. it makes this grinding noise when i let the clutch go too fast on first gear or even let it go slowly but push hard on gas. the noise also comes from second gear but i couln't really tell and it also has a really difficult time to shift. . it is not as smooth as other cars i drove. This was going on before my clutch or whatever went out. what is the problem, transmission or the clutch.
thank you
Jan 3, 2006 at 4:51 PM
PALCO
  • 83 POSTS
clutch slipping is my thought.
Jan 3, 2006 at 7:19 PM
INLOW1990
It seems like its grinding gears and you probably should look into a new clutch but you have to have the timing set exactly right or its gonna be bad
Feb 27, 2006 at 8:20 PM
MECHTRIX
  • 382 POSTS
sounds like its the input shaft bearing syncro rings if not more in the transmission and the throwout bearing 'pressure plate' friction disc ' flywheel resurface...good luck"
May 4, 2011 at 7:48 AM
