charging problems
CHEVROLET IMPALA
VOYAGER185
i own an 89 corvette 55k miles, problem is not charging, not the alternator, had it checked off the car at autozone. battery was replaced in august just due to age. wiring looked ok. any suggestions?
Jan 1, 2006 at 11:42 AM
MOPARFANS
Check if the Engine is Well Grounded to the Frame or the Body, if he's not, it will affect the Alternator and result in not charging well and giving wrong information on the gauge in the car or maybe its the Regulator that has gone and that's the result why your Alternator work but he's not charging the battery ! Take a Look, maybe the Regulator is not inside your Alternator, its somewhere in the Engine Bay connected ! Check That !
Andrew
Jan 1, 2006 at 3:18 PM
HOTWHEELSGMC
  • 31 POSTS
my guess is that it's your alternator, even though you had it checked...take it to a mechanic and have it checked while the car is running.
Jan 16, 2006 at 5:25 PM
MER449S
  • 6 POSTS
I run older cars for many years. Everyone of them need ground wire attention after about 15 years. Make sure all three of your main ground wires are in good condition. Don't forget the heater motor.
:roll: If any of these are not fully connected., you may receive all kinds of strange happenings: batteries that don't charge, lights that blow out prematurely, runs rough, fuses that don't last, even strange shorts here and there, popping sounds as the electricity finds its way out through whatever available source it can find, transmissions that don't shift right, car that dies every time you turn the heater on.
:wink: Most makes and models have a ground on the block, on the transmission, and on the heater. Personally I put an extra ground from the starter to the body for good measure because the one on the block sometimes goes bad and cannot be easiely rerouted. This serves to replace the old ground wire on the block, secures my car against future aggravation, and gives me piece of mind that it will be running smoothly down the road.
:oops: Hope this helps
Jan 29, 2006 at 2:16 AM
