'88 190E 2.3 engine wiring
1988 CHEVROLET IMPALA
SPEAKERTIM
Hi, I have an '88 190 E with the 2.3 gas engine. The wiring harness in the enging compartment has a couple broken wires and is missing some connectors. I picked up a new harness but still do not have a diagram to make sure everything is hooked up correctly. Do you know where I could locate a wiring diagram for the engine compartment?
Thank you for your time.
Tim
Jan 9, 2006 at 2:47 PM
WILLIAMDON
[quote:bf098f97af="speakertim"]Hi, I have an '88 190 E with the 2.3 gas engine. The wiring harness in the enging compartment has a couple broken wires and is missing some connectors. I picked up a new harness but still do not have a diagram to make sure everything is hooked up correctly. Do you know where I could locate a wiring diagram for the engine compartment?
Tim[/quote:bf098f97af]
tim.....look in web site thebenzbin.com and they show how the data can be obtained on \cd...only available genuinly on CD...but not cheap...I had same prob..
Jan 10, 2006 at 5:22 PM
