The drivers door lock does not consistently function via the remote. All other locks function fine but the drivers door either will not function at all or will only go half way when you press the button on the key fob. I have checked inside the door and it does not appear that anything mechanical is binding. I don't know much about this system I assume that there is an antenna and central receiver and then an actuator on each door lock. Would this be a problem with that local actuator and not the whole system? Thanks...
Oh and the lock works fine when manipulating it manually or with the physical key
May 12, 2010 at 7:40 PM
