Wipers Blades Do Not Park
Step
Action
Value(s)
Yes
No
1
Did you review the system operation and perform the necessary inspections?
Go to Step 2
Go to Symptoms
2
Turn the ignition switch to RUN.
Turn the wiper switch to OFF.
Disconnect the wiper/washer switch connector.
Do the wipers park?
Go to Step 3
Go to Step 4
3
Replace the wiper/washer switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Did you complete the replacement?
Go to Step 9
4
Measure the voltage from the wiper/washer switch connector (vehicle side), terminal B6, to ground.
Does the voltage measure greater than the specified value?
1.0 V
Go to Step 6
Go to Step 5
5
Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
Go to Step 9
6
Reconnect the wiper/washer switch connector.
Disconnect the wiper motor connector.
Measure the voltage from the wiper motor connector, terminal D, to ground.
1.0 V
Go to Step 8
Go to Step 7
7
Go to Step 9
8
Repair the short to voltage in CKT 113. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Apr 3, 2008 at 9:28 PM
