2004 Chevy Impala Top Engine knock
2004 CHEVROLET IMPALA
98,000 MILES • 6 CYL • FWD • AUTOMATIC
CROOKEDTOE63
I have a 2004 Impala that has a bad sound coming from the top of the motor. I recently had the rod bearings replaced but its still making a clacking sound like its out of oil (i know its not). Some people say its a stuck hydraulic valve lifter. Is it OK to drive like that? Could it be the cam or crank? Rod bearings were completely gone but I still have a knock. They were thin all the way to the bottom metal to metal. I was told that was the problem, but obviously its not. If the cam bearings are bad, whats the general cost to fix that? Or should I replace the motor? The car is paid off.. How long would it take to fix?
Sep 9, 2009 at 4:16 PM
Are you getting good oil pressure? Yes it could be cam bearings, but when the rod bearings were replaced, did they have the crank cut and use oversized bearings? Even with new bearings, a worn crank will still make noise.
Sep 22, 2009 at 10:51 AM
