I have a 2004 3.4L Impala. The fuel pressure regulator is leaking where it connects to fuel rail. The manual calls for taking off the upper intake to gain access. That seems a little excessive . I did find some info stating you could gain access enough by removing the throttle linkage , which looking at it seems possible. Also read to where someone else was experiencing the same issue , basically started smelling gas at times and today the regulator was wet with gas appearing to come from between regulator and fuel rail. The other person who had same issue stated he changed regulator and within a couple weeks had same issue. Now either he didnt put it back together properly and caused another leak or there is something else causing this. What would you do?
Dec 8, 2008 at 10:10 PM
