The car sometimes stalls after starting and when started it runs rough. The fuel gauge will read E to 1/4 of tank when there is more than 1/2 or more fuel in tank. To me it sounds as if there fuel supply problem or maybe water in fuel.
Changed the fuel filter with oem replacement. Checked fuel pressure. The gauge reads 55 psi when dead heads. And 50-52 psi when running. The gauge jumps to 58 psi when engine is running and regulator vacuum is disconnected. Gauge jumps 5 psi with engine running with WOT.
Connected my snap on scan tool. And 2 codes are present P0230 Fuel pump control circuit problem and P1626 Anti-Theft system fuel enable circuit.
Checked connections on fuel pump wiring harness. All are good and NO corroded termials. Any ideas on were the problem/s maybe?
Apr 5, 2010 at 11:49 AM
