Welcome to 2carpros and TY for the donation
Notes
Water Pump Replacement (RPO's LZE/LZ4/LZ9)
Removal Procedure
Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
Loosen the water pump pulley bolts.
Remove the drive belt.
Remove the water pump pulley bolts and pulley.
Remove the water pump bolts.
Remove the water pump and gasket.
Clean the water pump mating surfaces.
Installation Procedure
Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
Install the water pump pulley and bolts.
Install the drive belt.
Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
Inspect for leaks.
Apr 28, 2018 at 3:11 PM
(Merged)
