I replaced right rear power window motor with a reman.from NAPA. The new motor only works in down mode. Went back to Napa and tried another motor and same result. I swaped left switch to see if switch. same result.I ran jumper wire from down wire to up prong on motor and motor does operate in other direction. Only thing I figure is green wire from harness to front left window did pop when I tried to check for voltage. Both prongs to motor is getting voltage and I pushed contacts down with a small screwdriver for contact with motor prongs. I even replaced relay switch which wasn't bad either. I get voltage from every wire on switch plug except the green wire. I tried to find 30 amp fuse in driver side fuse box which owners manual indicated. no Luck.
May 5, 2009 at 12:57 PM
