blower motor not working
2003 CHEVROLET IMPALA
S-SCHOP1
  • 28 POSTS
Electrical problem 6 cyl Two Wheel Drive Automatic
this vehicles climate control will not come on, the blower motor is not working,the a/c button doesn't light up when pressed.i found that in the fuse block on the drivers side of the dash that the blower motor fuse has no power. if i supply that fuse with power then everything works normally.all other fuses are good. my main question is,where does this fuse receive power from. thank you for your help in advance.
Aug 4, 2010 at 12:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
According to the schematics, the A/C Blower Fuse (25 amp) will have an orange wire going to the blower motor relay. Have you tested the relay out? From the relay it will go to multiple places, including the blower motor itself and the HVAC Control Module.
Aug 4, 2010 at 10:53 PM
S-SCHOP1
  • 28 POSTS
the fuse i have no power at is in the drivers side fuse block (20 amp). where is the blower motor relay? im going by the fuse panel covers and none of them say blower motor relay. thanks.
Aug 5, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the blower motor relay is integral with the blower motor resistor , sorry I just noticed that. i see the other A/C fuse you speak of, has a brown wire going to it. it goes to the same places as the other I listed, but if the fuse itself doesn't have power then it must be the wiring going to it at fault because it gets power from the battery to the fuse, then from fuse to the other components.
Aug 5, 2010 at 2:31 PM
S-SCHOP1
  • 28 POSTS
ok,thanks. is there any way i could get a wiring diagram of this circuit?
Aug 5, 2010 at 2:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sure it's rather large though and probably not readable on this forum, so i have sent it to your email on file as well. (UPDATED WIRING DIAGRAMS LOCATED AT THE BOTTOM OF THIS POST)
Aug 5, 2010 at 2:55 PM
S-SCHOP1
  • 28 POSTS
awesome thanks! also have you heard of any of these concerns caused by the BCM? this same car has the security light,the trunk ajar light,the airbag light,and the low tire light on also.I know.....WOW.
Aug 5, 2010 at 3:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yep that's usually a sign of a crazy computer (aka BCM, PCM etc...). none of those things are related at all other than that the computer has last say in all of their functions.
Aug 5, 2010 at 3:39 PM
S-SCHOP1
  • 28 POSTS
could the bad bcm be the cause of my a/c problem?
Aug 5, 2010 at 11:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
don't think it could cause the fuse not to have power because again the power comes straight from battery to the fuse box.
Aug 5, 2010 at 11:04 PM
S-SCHOP1
  • 28 POSTS
ok,i'll start digging.thanks again.
Aug 5, 2010 at 11:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
no problem, let me know how it goes and if you need further assistance just post here.
Aug 7, 2010 at 11:21 AM
S-SCHOP1
  • 28 POSTS
just wanted to give you an update. the reason the fuse for the a/c control head wasnt getting power was the ignition switch. the orange wire coming from the ignition should have power with the key in the on position,mine didnt. i replaced the ignition switch and problem solved. also as far as the car dying and the multiple insturment cluster warning lights,the battery was shot tested it three times and it failed every time.replaced the battery and havent had a problem since. yay
Aug 24, 2010 at 3:39 AM
Glad you could get it fixed please use 2CarPros.com anytime we are here to help.
UPDATED WIRING DIAGRAMS BELOW
Best, Ken
Apr 10, 2017 at 12:49 PM
JWMCALLIS
Heater problem
2003 Chevy Impala 6 cyl Front Wheel Drive Automatic 168000 miles
The heat/AC blower on my 2003 Impala has only worked on the highest setting (5) for over a year now. Just last week, it stopped working completely. I can hear a clicking noise when I switch back and forth from 4 to 5. Winter is getting closer and I really will need as much heat blowing out as possible! Thanks for any insight you can provide.
Apr 10, 2017 at 2:54 PM (Merged)
Power the blower motor from the battery if it comes on do below
Inspect and test the blower motor relay and the blower motor resistor
PHIIP982
Electrical problem
2003 Chevy Impala 6 cyl Front Wheel Drive Automatic 78000 miles
THE FAN HAS 5 SPEEDS, 1 & 2 SPEEDS DON'T WORK, 3,4 &5 WORK. HOW DO I REPLACE THE SWITCH?
RHALL77
  • 3,361 POSTS
its not the switch its a blower resistor. it is located on the passenger side lower part of the hvac box
CRPGNUT
Air Conditioning problem
I was driving in to work and had the A/C on. The blower was running fine and just stopped completely. It doesn't work on any setting from 1-5. I swapped the fuses on either side of the car and that didn't seem to do anything. Changing to defrost or heat doesn't seem to make a difference. I can hear the A/C kick on when pressing the button, but no blow.
Thanks for your help
SATURNTECH9
  • 30,869 POSTS
What model impala do you have?Also do you have manual or auto climate control?Let me know so i can get you the correct information.
CRPGNUT
3.8 V6 and I guess manual climate control. I have to press a button to turn it on or off. There's no letters after my Impala name. It's not a LS or anything.
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part4_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part5_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part6_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part7_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2003_chevy_impala_blower_motor_inop_part8_1.jpg
There you go.
SHEENA RENEE ALVARADO
I'm having the same issue. It won't blow any air at all. I can hear the ac kick on but not air flow. Changed the fuse on passenger side fuse box it was bad but it didn't help the air blow. I have a 2003 LS any suggestions?
Apr 26, 2017 at 10:47 PM
Can you hear the blower fan working, like its trying to blow air?
Best, Ken
Apr 27, 2017 at 1:35 PM
I can hear something kick on but it sounds like it is something under the hood. I assumed it was the compressor but i have no idea what it is, i just know this Texas heat is making it worse.
Apr 27, 2017 at 4:24 PM
SATURNTECH9
  • 30,869 POSTS
If it's not working at any speed it's a good chance it's the blower motor.Bad news it's under the hood area at the base of the windshield.You have to remove the wiper arms cowl cover wiper motor with wiper transmission then there is a cover over the blower motor.Also care has to be taken putting the blower motor cover back on.Otherwise the blower motor wheel will rub on the blower motor cover.if you turn the blower motor on the highest setting.Your looking for power on the yellow wire under the dash on the passenger side of the dash.
Apr 29, 2017 at 8:22 AM
SATURNTECH9
  • 30,869 POSTS
There is a blower motor resistor card with a plug towards the center of the dash under it on the passenger side that's where your looking for the battery voltage.
Apr 29, 2017 at 8:30 AM
