I have been experiencing intermittent problems between the high beams, cruise control, and the a/c. The only constant is the high beams. When the key is in the on position, the high beams will flicker and occasionally the instrument cluster will reset. With the key in the off position, the high beams work fine.
After the car is started, sometimes the cruise control indicator will come on but the control won't work and if you turn on the fan, the cruise indicator will go out and the a/c controls will function after about 30 to 60 seconds; or the cruise control will operate as normal and then drop out at some point; or the cruise control will operate with no problems. The problem with the cruise control seems to be aggravated if the steering column is adjusted often.
I have checked fuses and everything checks out ok, I suspect something in the steering column but am not sure, any other suggestions? I'd just like to know before I take it in. I'd do it myself if it weren't for the airbag in the steering wheel.
Sep 28, 2008 at 3:03 AM
