front seat heaters?
2003 CHEVROLET IMPALA
96,545 MILES • 6 CYL • FWD • AUTOMATIC
AUSTINCR
  • 6 POSTS
Is there an easy way to replace the front seat heater in the bucket seats?
Jan 27, 2009 at 2:33 PM
RHALL77
  • 3,361 POSTS
basically remove the bolts, disconnect the electrical connectors and slide it out. Here are the instruction in the diagrams below to help you.
Jan 27, 2009 at 6:21 PM
AUSTINCR
  • 6 POSTS
I didn't see bolts in the tracks. The only bolts I saw were up in the seat and very difficult to get a wrench on. The nuts are welded so I think I must turn the bolts from the top.
The heater isn't working in the drivers seat.
Jan 28, 2009 at 7:51 AM
RHALL77
  • 3,361 POSTS
pull the carpet back a bit they should be right there. move the seat all the ways forward and you'll see them.
Jan 28, 2009 at 8:48 AM
MARTYB213
I have car seat heaters on the driver and passenger seats. The front passenger seat works, but the drivers seat does not. How do I find the problem and fix it?
May 4, 2020 at 2:47 PM (Merged)
RHALL77
  • 3,361 POSTS
sounds like the element may be bad. check your fuses first and see if they are ok. Does it shut off right away when you turn it on?
KIMMERER RIZOR TRIPP
How can I get an original heating element for the drivers side seat on my Impala?
Nov 11, 2020 at 12:48 PM
Unfortunately the only way you are going to replace them is the seat cover has to be replaced. There may be some interior shops that work on this stuff willing to take them out and sew in new ones but I figure most will just tell you to replace them.
I attached the process for this. Let me know if you have questions or need other info.
Nov 11, 2020 at 1:07 PM
