2002 Chevy Impala Normal temp
2002 CHEVROLET IMPALA
65,000 MILES • 6 CYL • FWD • AUTOMATIC
ELLEN H
  • 4 POSTS
For a month the temp gauge has been higher than normal. Just under half for highway speeds and warming to half or just over in traffic. Had both upper and lower intake manifold gaskets (a problem with the 3.8 engine it seems) replaced, and coolant flushed, new oil. Oil had supposedly gotten into the coolant. No coolant leaks.
Well this didn't change my temp gauge readings. Had an independent shop run a computer temp with the engine warm. It read 202-208 when revving. Dropped at just idling. Engine temp directly read 196 at idling. They don't think there is a problem.
Do I just get used to the "new norm" on my temp gauge?
May 18, 2010 at 1:26 PM
2CARPRO JACK
  • 11,533 POSTS
Newer vehicles are run around 200 for emisisons purposes.Sounds like you are runing right in the correct range. Some electric fans dont even turn on until 225+ I wouldnt worry about your car, sounds like it is ok
May 18, 2010 at 1:36 PM
ELLEN H
  • 4 POSTS
Thanks for your help
May 18, 2010 at 2:08 PM
2CARPRO JACK
  • 11,533 POSTS
You are welcome, thanks for using 2Carpros.com
May 19, 2010 at 7:48 AM
