2002 Chevy Impala hesitation
2002 CHEVROLET IMPALA
LCGATOR
Engine Performance problem
2002 Chevy Impala 6 cyl Front Wheel Drive Automatic 104k miles
I just had my trans serviced & oil changed and a couple days later my car hesitates upon acceleration when warm especially @ low speeds. I doubt its anything to do w/ trans but worried it may be timing belt? i've looked online and found lots of scenarios just wandering what the most likely cause may be considering my make/model/mileage/year etc.
Apr 20, 2009 at 10:27 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Apr 20, 2009 at 10:57 PM
Bad plug wires
Weak ignition coil
Wet plug wires
Apr 20, 2009 at 11:23 PM
LCGATOR
if my car whistles when i accelerate is that a sign of vacuum leak?
Its been doing that a while but hesitation just started
Apr 21, 2009 at 4:02 AM
Could be check between the MAF and throttle body unit
Apr 21, 2009 at 4:15 PM
