RESETTING ENGINE OIL LIFE SYSTEM Using Radio Data System (RDS) Equipped Radio 1. Turn ignition switch to RUN or ACCY position. Ensure radio is off. Press and hold DISP button on radio for at least 5 seconds until SETTINGS message is displayed. 2. Press SEEK button up or down to scroll through main menu. Scroll until OIL LIFE is displayed. Press PREV or NEXT button to display sub-menu. RESET will be displayed. Press DISP button to reset. Chime will be heard and DONE will be displayed for one second. 3. After reset has been accomplished, scroll main menu until EXIT is displayed. Press DISP button to exit programming. Chime will verify exit. Using Accelerator Pedal Turn ignition switch to RUN position. Fully depress and release accelerator pedal 3 times within 5 seconds. If CHANGE ENGINE OIL message flashes, system is reset. If CHANGE ENGINE OIL message does not flash (remains illuminated), repeat resetting procedure.
Feb 28, 2009 at 1:56 PM
