2002 Chevy Impala Advice needed desperately!!!
2002 CHEVROLET IMPALA
108,000 MILES • 6 CYL • FWD • AUTOMATIC
GEOPOCALYPSE3000
  • 11 POSTS
I have replaced a starter, all spark plugs and cables, battery, alternator, throttle position sensor, MAF sensor, catalytic converter, 02 sensors and a plethora of other items and my car continues to stall out several times a day (highway, city driving, even when stopped).
As of last night the car stalled out completely on the highway almost killing my girlfriend and I as I lost all power steering and just barley got the car off the road. We also smelled a strong mixture of smoke and gasoline (very sulfur-like) and noticed a hint of smoke coming from the engine bay.
After a few minutes the struggling car finally started back up. This morning as I get ready to leave for work the car was struggling for several minutes horribly before finally turning on and once again producing the same sulfur-like smell.
I have my oil changes regularly, transmission flushes, engine flushes, and coolant system flushes whenver needed so I stay very much on top of my regular maintenance schedule.
PLEASE HELP!!! (by the way, no check engine light).
Jan 27, 2009 at 8:27 AM
DOCFIXIT
  • 18,828 POSTS
Check fuel pressure regulator pull vacuum hose off if fuel present replace reg.
Jan 27, 2009 at 8:45 AM
GEOPOCALYPSE3000
  • 11 POSTS
The car is now in the shop and the mechanic just told me 2 hours ago that he was going to check fuel pressure first. Hopefully this solves the problem!!!
Thanks!!!
Jan 27, 2009 at 9:27 AM
DOCFIXIT
  • 18,828 POSTS
Sounds like you have a good Tech. looking at car.
Let me know what he finds
Jan 27, 2009 at 9:39 AM
GEOPOCALYPSE3000
  • 11 POSTS
The tech checked the fuel pump and fuel pressure and both were working perfectly. The fuel filter was EXTREMELY clogged and replaced. The car ran great all night (although the steering felt a little tighter then usual). My area had some significant snow this morning so I decided to warm it up early. The car did not turn on the first three tries. On the fourth try the car did turn on but was idling very rough (boucing rpms constantly from 500 - 2000 and still NO CHECK ENGINE LIGHT).
After a minute the engine calmed down and sounded normal and the rpm's settled around 700-800. I allowed the car to run for 15 minutes to bring the engine up to temperature (its 20 degrees right now outside) before leaving for work. Needless to say, the car stalled out twice on the way (both times while going down hill).
Any more advice before this vehicle becomes my casket?
Jan 28, 2009 at 8:57 AM
DOCFIXIT
  • 18,828 POSTS
Would clean MAF and verify EGR operation. Maf will cause idle swinge and stalling. EGR will stall on decelerationj if not closing.
Jan 28, 2009 at 11:02 AM
GEOPOCALYPSE3000
  • 11 POSTS
MAF was replaced two weeks ago along with the Throttle position sensor.
Jan 28, 2009 at 11:18 AM
GEOPOCALYPSE3000
  • 11 POSTS
I have noticed that my steering has gotten significantly stiffer, especially when coming to a stop or when stopped altogether.
Right now I am experiencing the shutting off moreso when the car is sitting idle.
Example: The car turned on and drove great all day yesterday yet when I drove to my girlfriends job the car stalled out as soon as I parked. It then stalled as I was leaving a parking space at a local gas station.
I am seriously running out of money...
Jan 30, 2009 at 7:10 AM
DOCFIXIT
  • 18,828 POSTS
Did you verify EGR operation? that will cause stalling and idle swings. Steering does it get stif as temp drops? Has fluid ever been changed? I ask because hydraulic fluid will absorb moisture as it ages.
Is your Tech useing a diagnostic scanner? Not code reader a scan tool that can check all computer controled items ? That is what must be done cause all you are doing is throwing parts at it.
Jan 30, 2009 at 9:02 AM
GEOPOCALYPSE3000
  • 11 POSTS
The power steering fluid has never been changed as far as I know and the temperature in my area has been in the 20's for the last two weeks or so.
I am contemplating cleaning my IAC valve but unsure of what to use to do so. Would CRC MAF cleaner work?
I will try and schedule an appointment to have a serious diagnostic done early next week and let you know what I find out.
Thanks for everything thus far.
Jan 30, 2009 at 9:12 AM
DOCFIXIT
  • 18,828 POSTS
Yes cleaning is good idea and MAF cleaner is good.
Get passage ways and pentile and while in area clean throttle body open ues tooth brush and cleaner.
Jan 30, 2009 at 9:29 AM
DVCRPM
[quote:2622634837="geopocalypse3000"]Electrical problem
2002 Chevy Impala 6 cyl Front Wheel Drive Automatic 108000 miles
PLEASE HELP!!! (by the way, no check engine light).[/quote:2622634837] Sounds like vaporlock have you changed the fuel and air filters lately?
Feb 1, 2009 at 11:10 AM
DVCRPM
[quote:86adc4ecc6="dvcrpm"][quote:86adc4ecc6="geopocalypse3000"]Electrical problem
PLEASE HELP!!! (by the way, no check engine light).[/quote:86adc4ecc6] Sounds like vaporlock have you changed the fuel and air filters lately?[/quote:86adc4ecc6] And possibly cat converter.
Feb 1, 2009 at 11:12 AM
GEOPOCALYPSE3000
  • 11 POSTS
The catalytic converter is only three months old. The fuel filter is only 5 days old and the air filter is less than 2 months old.
Any other ideas?
Feb 1, 2009 at 12:49 PM
GEOPOCALYPSE3000
  • 11 POSTS
BTW: As I was driving Saturday morning the car died (as usual) several times on the way to my father's house. I noticed a blinking check engine light but before I had the chance to get to an Autozone to have it scanned the car turned off several more times and the blinking light never came back on...
Feb 2, 2009 at 2:27 PM
DOCFIXIT
  • 18,828 POSTS
I getting more inclined to suspect the PCM. You have weird stuff then it gets better everything checkes out new parts work for a few days. An electronic component is only thing that can do that. Mechanical part when it breaks it stays broke.
Feb 2, 2009 at 2:57 PM
GEOPOCALYPSE3000
  • 11 POSTS
I am trying my best to stay positive. How would a faulty PCM be diagnosed?
Feb 2, 2009 at 3:08 PM
DOCFIXIT
  • 18,828 POSTS
That's the rub there isn't maybe an elecronic geek could figure out. But I go on 40 yrs experience and when you have a car like yours it is alikely course. You can't rely on PCM to diagnosis as in your case. Light on, no light check for codes none. All those parts you would think the odds of geating it right would have played by now.
Feb 2, 2009 at 3:21 PM
GEOPOCALYPSE3000
  • 11 POSTS
I am constantly being told to replace the fuel pump and fuel pressure regulator but because I have seen SECURITY, TRAC OFF, SERVICE TRAC SYSTEM lights come on right before the car turns off I am thinking more towards the car's computer as well.
Pep Boys has a $100 total system/sensor scan. Should I invest in that first considering I already own my own scantool?
Feb 2, 2009 at 3:26 PM
DOCFIXIT
  • 18,828 POSTS
This is what I suggested last Friday your scaner only reads codes. This test is with a diagonist scan tool . It interfaces with PCM checks all sensors, actuators, injestors all components. This should help determine if PCM is faulty.
Feb 2, 2009 at 3:39 PM
GEOPOCALYPSE3000
  • 11 POSTS
I am finally able to pull a code from my OBD-II and it is P0103 - MAF High circuit input. My only problem is that the MAF was replaced just shy of a month ago.
Feb 13, 2009 at 7:01 AM
BOBBYTECH1
  • 49 POSTS
i noticed that on the previous pages u mentioned thet ur engine light was blinking while u were driving what u should do is drive the car with scanner on snap on will be good and drive with the live window on the scanner on misfire data to see which cylinder is misfiring if u can accomplish that that will take u one step closer to ur problem
Feb 16, 2009 at 10:04 AM
GEOPOCALYPSE3000
  • 11 POSTS
My car is now parked at the local Chevy "Stealership" after noticing that my radiator had exploded. They still believe it to be my MAF sensor since I didnt replace it with a OEM GM part.
$1,400 to fix everything and then a diagnostic will be completed... my luck!!! LOL
Feb 16, 2009 at 10:53 AM
BOBBYTECH1
  • 49 POSTS
lol, u should ask them b4 u replace maf that why did the rad exploded, in my opinion u hav a compression leak in the cooling system causing tremendeous pressure that sort of explains why would ur engine light will flash,
maf will not cause ur rad to blow up, i hav bought afterrmarket mafs many times
Feb 16, 2009 at 5:19 PM
