2001 Chevy Impala WINDSHEILD WIPER
2001 CHEVROLET IMPALA
STONESFAN911
2001 Chevy Impala 6 cyl
My winsheild wipers are out of sync and they jam into each other but when I take the wiper assembly off (drivers side) and just leave the arm they're not out of sync.
Dec 18, 2008 at 12:01 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you, if you need to get back with me, please tell me the model of your vehicle. Is it just and Impala or an LS. Also the engine size in liter and the 8th digit of your VIN.
Based off what you have said…..did they just start all of a sudden hitting each other?
Have you tried removing both wiper arms…….turn the wipers on and let them run…..then turn them off. They should be in park mode then. Now, re-attach the wiper arms to the lowest point on the windshield.
Dec 18, 2008 at 1:46 PM
STONESFAN911
It's an Impala with a 3.4L engine. It snowed with freezing rain, the driver side wiper wouldn't move but the passenger side did. After it thawed both sides would move and that when they start hitting each other. I took the passenger side wiper off and let the driver side run, it goes all the way over past the point it's supposed to stop at.
Dec 19, 2008 at 1:14 AM
IMPALASS
  • 3,112 POSTS
Hello –
It is possible you have stripped the gears on the arm or to the motor. Have you had time to do what I said above………..if not, try that and let me know.
Remove both wiper arms…….turn the wipers on and let them run for about a minute…..then turn them off. They should be in park mode then. Now, re-attach the wiper arms to the lowest point on the windshield.
Turn on and see how they do.
Dec 19, 2008 at 8:11 AM
IMPALASS
  • 3,112 POSTS
Hello –
I also wanted to let you know that it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
08089
06/13/2008
Campaign - Analog OnStar(R) Deactivation
05551
09/14/2005
Campaign - Catalytic Converter Warranty Extension
NHTSA01V136000
04/26/2001
Recall 01V136000: Fuel Return Line Defect
NHTSA00V371000
11/10/2000
Recall 00V371000: Air Bag Inflator May Separate
00073
10/19/2000
Recall - Air Bag Sensing/Diagnostic Module Replacement
NHTSA00V244000
08/25/2000
Recall 00V244000: Air Bag May Not Deploy
Dec 20, 2008 at 11:10 PM
