if you are talking about, the check engine light, some cars can reset the light just by unplugging the negative battery cable for a few minutes. once reconnected it may trigger another code , which is code 12, "battery recently disconnected". at this point you will need to let the car go through its relearn mode and if this vehicle is capable, it will reset itself, an alternative is, if you live near an autozone ,advance auto parts, checkers or even your local parts place will reset your engine codes for FREE.
Nov 15, 2008 at 3:23 PM
