Engine Mechanical problem
2001 Chevy Impala 6 cyl Two Wheel Drive Automatic 165K miles
I guess I didnt sent this right the first time, so I will try again. The pulley liocated beneath and to the right of the alternator, is that the idler tensioner pulley? If not, what is it , and If so, can its bearing go bad, and create a terrible grinding noise and send flecks of what appear to be aluminum on to the drive belt? No overheating, no hot water smeslls, juist a terrible grinding noise that did increase and decrease with engine RPM. I just need some help in deciding if it is worth the repair or not, and if so, what is the best approach? Please help. Thank you
Jan 18, 2009 at 10:38 PM
