2001 Chevy Impala clunks upon accelerating from stand-still
2001 CHEVROLET IMPALA
130,000 MILES • 6 CYL • FWD • AUTOMATIC
ROUSLEY7
MEMBER
FOLLOW
About once or twice a day, when accelerating from a stop, the car doesn't immediatley respond but then suddenly jerks out with a "clunk".
Mar 20, 2008 at 9:42 AM
RHALL77
CERTIFIED EXPERT
does it feel like the transmission is slipping? can you give me somemore information.
Mar 20, 2008 at 10:01 AM
SERVICE WRITER
CERTIFIED EXPERT
The transmission fluid may be low. Unfortunately this is not an easy thing to check on these.
If you can get a scanner to read codes, there may be a transmission one related...hard to say. Should get the level checked first and look for possible leaks. I can go through the procedure, but you really need a lift to do it.
Mar 20, 2008 at 10:05 AM
SERVICE WRITER
CERTIFIED EXPERT
I got your PM. IF you are sure this isn't a transmission issue than there is somthing physically holding the car back.
When this happens, does the engine idle raise like it should? Or is it non responsive to the idle as well?
Are the rear brakes drum brakes? Have there been any abnormal braking qualities such as a lock up or longer than normal stopping distances or a harder pedal?
