2001 Chevy Impala
2001 CHEVROLET IMPALA
RANDY1953
  • 7 POSTS
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic
my 2001 impala had some high water damage. The starter was broke, I replaced the starter, and now the starter turns but dont engage the flywheel. Starter bench checks o.k.
Aug 4, 2008 at 11:17 AM
Do you mean you can hear the starter engaged the engine but its not cranking over or it won't crank engine over at all-nothing happens when you turn key to start position? The new starter overrunning clutch could be slipping
Aug 4, 2008 at 12:15 PM
RANDY1953
  • 7 POSTS
The starter runs but does not engage the flywheel to turn over motor
Aug 4, 2008 at 12:40 PM
You're too far from the flexplate-try using shims. You sure you got the correct starter-double check
Aug 4, 2008 at 12:43 PM
RANDY1953
  • 7 POSTS
It is the correct starter I double checked,no shims required
Aug 4, 2008 at 1:01 PM
RANDY1953
  • 7 POSTS
solenoid does not kick in
Aug 4, 2008 at 1:03 PM
Check the ABS/PCM fuse 10amp and crank relay then get back
https://www.2carpros.com/forum/automotive_pictures/12900_abspcm_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_crank_relay_1.jpg
Aug 4, 2008 at 1:41 PM
RANDY1953
  • 7 POSTS
All fuses and relays ok, still nothing. Please help I will pay more if you can help fiqure this out
Aug 4, 2008 at 2:15 PM
Test the fusible link blue 18 gauge that's coming from the remote battery stud. This checked out its gonna come down between the ignition switch and computer. Hold key at start position and check computer control of relay purple wire whether it has power see below
https://www.2carpros.com/forum/automotive_pictures/12900_computer_1.jpg
Aug 4, 2008 at 2:27 PM
RANDY1953
  • 7 POSTS
fusible link ok
Aug 4, 2008 at 2:35 PM
Test the purple wire for power going to the computer see above circuit
The computer is in the aircleaner box
Aug 4, 2008 at 2:58 PM
