2000 Chevy Impala Sputtering
2000 CHEVROLET IMPALA
140,000 MILES • 6 CYL • FWD • AUTOMATIC
CRYSTALSMOTHERMON
When turning my vehicle on at first the engine was "reving high". after turning the car off then back on it retutned to a normal idle but then started sputtering like the fuel flow had been restricted.
Oct 12, 2008 at 2:58 PM
RHALL77
  • 3,361 POSTS
is there a check engine light on
Oct 13, 2008 at 8:31 AM
CRYSTALSMOTHERMON
Yes the check engine is on. Since posting this question I have had diagnostics ran and the result was intake manifold gasket gone bad. Manifold itself is intact and good but still an expensive fix. Firestone auto quoted 780.00 to fix. I have since taken the car by trailer to an independent shop owned by a friend and will have it fixed tomorow for a low 300.00! Wow! Still a big chunk of change. Fortunatley the only other thing that showed on the diagnostic test was plugs and plug wires that are being changed out as well.
Thank you for responding to my question though!
Oct 16, 2008 at 6:14 PM
