2000 Chevy Impala Rear wheel bearing assembly.
2000 CHEVROLET IMPALA
WILLIAM WILBURN
Drive Train Axles Bearings problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic
I am trying to change the rear wheel bearing assembly.
I removed the caliper,rotor,and 4 bolts holding the assembly in. The old assembly will not come off.
I'm assuming that it presses in when tightening,and is probably "corrosion welded".
How do I get the assembly off ?
Thank You.
Jan 3, 2010 at 5:28 AM
ERNEST CLARK
  • 1,730 POSTS
Just take a hammer and apply some taps to the side and back to loosen it. You don't have to worry about being gentle.
It should come right off.
Jan 4, 2010 at 6:00 PM
