2000 Chevy Impala
2000 CHEVROLET IMPALA
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
GARY SMITH
when i turn on head lights the engine will stall,manualy or when auto turns them on, also the head lights are staying on all the time not at full power with front parking lights
Jul 13, 2008 at 10:34 AM
MERLIN2021
  • 17,250 POSTS
Test the alternator and battery, use a voltmeter and check output with and without the lights, leave the voltmeter attached to the battery and crank engine, you want at least 10 volts....any lower and the battery is weak. Alternator should produce 13.8-14.8 volts with engine running. Any less and the alternaor should be replced as well. Then check all fuses and electrical connectors you can find, any corrosion or bent or pushed out pins should be fixed.
Jul 13, 2008 at 3:30 PM
