1996 Chevy Impala p0300
1996 CHEVROLET IMPALA
115,000 MILES • V8 • 2WD • MANUAL
96IMPALALT1
i was recently doig some burnouts and i had some oil leaked out from somewhere in front of my engine. bout 2 quarts. after i stated the car is when i noticed the oil level light, i noticed is was shaking and the check engine light was flashing. i got the owners manual and it said that meant a misfire. so far i checked the ignition control module, ignition coil and spark plugs. all tested out fine. i narrowed it down to the cap and rotor assuming it got some oil in it. and since i'm gonna be there i will also change the wires. i got a timing gasket set but got stuck on not being able to take off the crank pulley. and if possible can u describe the best way to replace all the gaskets and seals without moving anything that will later keep the car from starting?
Feb 24, 2009 at 9:34 PM
BMRFIXIT
  • 19,053 POSTS
Again what is it that you are trying to do
is it the timing cover ?
most common is the manifold gasket check it out 1st
Feb 25, 2009 at 5:33 AM
