1995 Chevy Impala ENGINE
1995 CHEVROLET IMPALA
DBLOCK
Engine Mechanical problem
1995 Chevy Impala V8 Two Wheel Drive Automatic
WHY DOES MY ENGINE START SHAKING REAL BAD AND SOMETIMES CUT OFF WHEN I PUT IT IN GEAR?
May 13, 2009 at 11:58 PM
MMPRINCE4000
  • 8,548 POSTS
There is a device called the TCC (torque convertor clutch lockup). If it is stuck (engaged) all the time it will cause the car to shake and stall. It is only supposed to engage at 35-45mph after shifting into high gear. You can try removing the connector and see if the shaking stops, otherwise it will need to be replaced or further diagnosis performed.
https://www.2carpros.com/forum/automotive_pictures/108325_impala_ss_1.jpg
May 14, 2009 at 7:02 AM
