2007 Chevy HHR Turn signal lever
2007 CHEVROLET HHR
59,000 MILES • 4 CYL • FWD • AUTOMATIC
JIMMIEZ
  • 31 POSTS
'07 HHR, I snapped off the plastic turn signal lever about an inch from the attached end and now it hangs by the internal wiring to the headlamp controls at the end of the lever. How do I disconnect these wires and remove the headlamp control mechanism from the end of the lever so I can replace it? I also would appreciate steering wheel removal steps, or whatever is necessary to get to the attached end of the turn signal lever.
Jan 30, 2009 at 11:41 PM
RACEFAN966
  • 5,029 POSTS
Ok no need to remove the steering wheel first off. Now remove the trim from around the column and then you will see the switch and unplug it and then depress the locking tabs and remove the switch. thats it so it say's. Here is a pic
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic3_2.jpg
The switch cost about 53 dollars at your local parts store. here is a pic of the switch itself too. Hope this all helps thanks.
https://www.2carpros.com/forum/automotive_pictures/249564_746986_1.jpg
Jan 31, 2009 at 9:21 AM
JIMMIEZ
  • 31 POSTS
Thanks Racefan966...what a relief not to remove the steering wheel to replace the turn signal lever. Should be a fairly easy job now. Appreciate the prompt and detailed answer with pics.
Jan 31, 2009 at 10:12 PM
RACEFAN966
  • 5,029 POSTS
No problem thats what we are here for. Thanks again and yes it should be fairly easy as it calls for about 30 min to do.
Feb 2, 2009 at 12:49 PM
RACEFAN966
  • 5,029 POSTS
So how did it go?
Feb 14, 2009 at 1:39 PM
JIMMIEZ
  • 31 POSTS
It's my son's car and he's not reall accessable so I haven't done the fix as of yet. Don't expect any problems though. Thanks for checking
Feb 14, 2009 at 7:50 PM
RACEFAN966
  • 5,029 POSTS
I see was just following up. Thanks
Feb 16, 2009 at 10:22 AM
JIMMIEZ
  • 31 POSTS
hey racefan966...I finally got to do this repair and it went pretty well, except for one thing. The instrument panel trim that surrounds the steering column and gage cluster prevented sufficient clearance for removing the switch from its housing on the steering column. Choices were to remove this trim piece or move the steering column to the right to provide clearance to remove the switch. I chose to loosen the steering column support bolts and was able to move the column to the right (about 1/8") just enough to get the switch out of its housing. The $54 switch fit in perfectly and all systems work properly. Job complete. Thanks for your help.
Mar 6, 2009 at 6:22 PM
VICTORIANORMAN
Here is good video showing the replacement. You can get the part for around $20 new if you look around a bit. https://www.youtube.com/watch?v=PagJ8-BpOeA
Mar 28, 2017 at 3:29 PM
Hey,
Great addition to this thread! Please feel free to help out on the site whenever it can add information that will help.
Best, Ken
Mar 31, 2017 at 1:32 PM
