Engine Cooling problem
2005 Chevy Express V8 Two Wheel Drive Automatic
took water pump off , found gasket w slight rust spot, replaced gasket,belts. still leaks when filling and engine stop. will replace with new pump. engine overheats, hot hose coming out the top of radiator when running, no hot air coming out of heater. how do i get coolant into heater core?
Jun 10, 2010 at 5:47 PM
