I started having battery problems about a month ago. I load tested the battery and it was bad, so I replaced that. A week later it was dead again, I took the alternator in and had it tested, it showed bad, so I replaced it. The next day it wouldn't start, so I took the starter in and had it tested and it showed bad, so I replaced that. It ran fine for the last eight days but now the battery is dead again. I have check the alternator and it shows to be putting out 14 volts and 130 amps. I have cleaned all of the battery terminals and wires. When I put the battery charger on it (i put it on the top posts and not on the side posts where the cables are) and set it to High 220amp start, it cranks right up. I don't know if its a power drain or what. Any ideas? Can you tell me how to identify a power drain?
Jun 16, 2008 at 10:49 AM
