1998 Chevy Express valves
1998 CHEVROLET EXPRESS
GREEHY57
Engine Performance problem
1998 Chevy Express V8 Two Wheel Drive Automatic
I had to replace my 5.7 after it threw a rod and i had a 76 block so i put it in and used the heads from the 98 vortec engine and now it will not hold a valve adjustment
Jul 8, 2010 at 5:18 AM
HMAC300
  • 48,601 POSTS
the block was changed because you have roller lifters. the earlier block did not have this. the only thing i can suggest other than changing the block itself is to see if someone like crane or one of hte aftermarket cam manufacturers have roller lifters that are hydraulic. Most of them are solid lifter. Also the push rods are shorter due to the roller lifters in the newere truck engine. You cannot use the hydraulic lifters from the 76 engine on the 98 cam as the it is steel and will eat the lifters/cam up in nothing flat, unless you have done that already. You can get an engine out of a 96 up i fyou like. that will be your best bet.
Jul 26, 2010 at 7:29 PM
