2005 Chevy Equinox location of battery
2005 CHEVROLET EQUINOX
SHEILASCHROEDER
Electrical problem
2005 Chevy Equinox 6 cyl Front Wheel Drive Automatic
I can not find the location of my battery and the owners manual does not give this info
Sep 6, 2009 at 2:56 PM
https://www.2carpros.com/forum/automotive_pictures/12900_147643_battery_1_1.jpg
Disconnect the negative battery cable (1). Loosen the battery positive cable terminal bolt. Disconnect the battery positive cable (2) from the battery. Loosen the battery hold down bolt. CAUTION: Do not tip the battery over a 45 degree angle or acid could spill causing serious personal injury. Remove the battery from the battery box. INSTALLATION PROCEDURE Install the battery to the battery box. CAUTION: Do not tip the battery over a 45 degree angle or acid could spill causing serious personal injury. NOTE : Refer to Fastener Notice in Service Precautions. Tighten the battery hold down bolt to 15 N.m (11 lb ft) . Connect the positive battery cable (2) to the battery. Tighten the positive battery terminal bolt to 17 N.m (13 lb ft) . Connect the negative battery cable (1) to the battery
Aug 29, 2018 at 4:33 PM
