1987 Chevy El Camino u joints
1987 CHEVROLET EL CAMINO
69 COUGAR
Drive Train Axles Bearings problem
1987 Chevy El Camino V8 Two Wheel Drive Automatic
how do you change the u joint on a driveshaft on a 1987 chevy el camino
Oct 4, 2009 at 3:23 PM
If they are the original u-joints, you will need a torch to remove them. After you remove the drive shaft, you will see where there was a product injected into the end where the joint is. Heat it with a torch. Eventually, the compound will squirt out. Next, place a large socket (larger than the u-joint cap) under one side of the joint. Align it so the end cap can push into it. Next, take a socket that is slightly smaller than the endcap on the opposite side and hammar the cap through.
Let me know if this helps. It is harder to explaine than it is to do.
Nov 6, 2009 at 10:10 AM
