1981 Chevy El Camino master cylinder
1981 CHEVROLET EL CAMINO
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
GARAGEMEKANIK613
  • 5 POSTS
How can you tell when a master cylinder is bad? Trying to bleed a brake system and still pedal goes all the way down after pumping bleeding air out.
Nov 30, 2009 at 9:08 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, close off the bleeder and pump up the pedal till you have some pressure, hold light but constant pressure on the brakes, if the pedal slowly drops away it will be faulty, if you have constant air in the system, and there are no leaks to bee seen, the rear seal of the master will more than likely be drawing in air.
Mark (mhpautos)
Nov 30, 2009 at 9:32 PM
