I have a 80 305 eng. which has been bored 60 R/V cam, edelbrock carb,edelbrock torker intake. Ihave checked the compression (140/150) all cyc..I keep thinking I have a vacum link . At about 900 to 1500 rpm the eng. seems to have a small surging.I have used carb cleaner to locate a vacume leak at the base of the carb.and around the intake. (found nothing) blocked the brake booster,didn,t help. the vac. at the carb base is around 11 . what shold it be? what should it be going to the brake booster? The carb was kited a few months back.but at times smells gasy. How do you set the curb idle jets? 7 out of 10 times this eng. will start at the bump of the starter, at times you have too spin it over & hold excelator to the floor as if flooded. Got any sugestions ? P/S How do you set the detent on the trans.should the cable be taught or have some slack in it?
Sep 20, 2010 at 12:01 AM
