1979 Chevy El Camino car crank exceessively after normal te
1979 CHEVROLET EL CAMINO
1,000 MILES • V8 • 2WD • AUTOMATIC
JULIO NAVARRO
cold it would start up fine.but after driving around until needle hits normal tempeture and shut it down,it cranks along time turn it back on,i have to let it sit down,then i can crank it back up.this problem is draining my battery alot,well hopefully i hear from u guys.thanks
May 19, 2009 at 1:42 PM
DOCFIXIT
  • 18,828 POSTS
Maybe hot soak condition. When it's hot shut off see if fuel is leaking from carb into engine. Do you have a 4-BBL or 2?
May 19, 2009 at 1:53 PM
JULIO NAVARRO
4 bbl edelbrock 650 cfm
Jun 3, 2009 at 7:26 PM
DOCFIXIT
  • 18,828 POSTS
Check coil spark see if it is blue/white and check fuel pressure maybe vapor lock
Jun 4, 2009 at 1:37 PM
