New starter, new battery, new battery wires.
The car suddenly stopped sarting, no click, no sound or action from turning the key. How do you remove the ignition switch, & how do you remove the netraul saftey switch? These are the only thing left that I can eliminate in the ignition loop? Besides the wire that runs to the fuse block wich I will also replace, alt has worked fine before this no start problem.
Nov 27, 2008 at 4:16 PM
