1972 Chevy El Camino Engine won't crank when hot at times
1972 CHEVROLET EL CAMINO
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAVESH
My El Camino at times will not crank when the engine warms up. It does not overheat. Yesterday I started her up because i had not done this is 2 weeks, left her idling for about 5 minutes. I switched her off and wanted to start her up again and it did not crank. The generator light came on, I do not think its the battery(new).
I would appreciate some guidance on the problem.
Apr 14, 2009 at 2:06 AM
BMRFIXIT
  • 19,053 POSTS
Try and give it a jump does it start if so
Start and check the charging system
check if the heat shield on the starter was removed
and if so you may need to have one
check ground wire
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Apr 14, 2009 at 6:10 AM
