1968 Chevy El Camino Cranking problem
1968 CHEVROLET EL CAMINO
157,000 MILES • V8 • 2WD • AUTOMATIC
BERGJR
Engine will not crank after sitting for a while, though with a battery charger's 75 amp starter setting it will crank and start OK. If it cranks at all, it's full speed, no slow cranking. All or nothing.
Note: When a remote starter switch is connected to starter solenoid's S terminal and battery terminal, it cranks just fine.
Aug 23, 2010 at 7:49 PM
JDL
  • 16,098 POSTS
I'd have to make sure the battery has a full charge and the battery connections are good. That purple wire at the solenoid S terminal, is hot, whith the key in the crank position? Check without using a jumper or anything.
https://www.2carpros.com/forum/automotive_pictures/170934_el_camino_starter_circuit_1.jpg
Aug 24, 2010 at 1:41 PM
