Electrical problem
1964 Chevy El Camino V8 Two Wheel Drive Manual ??? miles
I recently had starting problems with my 64 El Camino that made me think the starter was failing. The starter would make a slow grungy sound before fully engaging, and then it just quit turning. Upon removal of the starter it was obvious that it had seen better days. I bought a new one and installed it. When I tried to start it I got nothing. Not even a solenoid click. Starter is connected correctly and starts when you cross the solenoid and battery cable at starter with a screw driver. I was told if this works the starter/solenoid are good. I also am getting a 12 v reading from the ignition switch wire that runs to the solenoid. I was told it may be the ignition switch even though I am getting a 12 v reading on my multimeter when the ignition switch is turned to start. I removed the ignition switch and noticed there was areas that look as though it got hot at one time on the plastic connector that connects to the back of the switch. No further investigation at this time. Any ignition switch experts out here?
Sep 14, 2009 at 10:17 PM
