intake instal question.
CHEVROLET CORVETTE
RICK BUTLER
I'm looking at an Eldelbrock dual 4bbl setup,with two 500cfm carbs.What I need to know is what mods if any I need to make. This setup is for looks and not for speed. I have a 75 L48 corvette with a stock 350, 8-1 compression ratio.I have been told by JEGS that it is bolt on with no mods,however several people tell me that I have to change the cam,and the heads. So any advice you have i would apreicate.
Aug 29, 2007 at 10:02 PM
DENNYP
  • 1,824 POSTS
[quote:a810c581ef="rick butler"]I'm looking at an Eldelbrock dual 4bbl setup,with two 500cfm carbs.What I need to know is what mods if any I need to make. This setup is for looks and not for speed. I have a 75 L48 corvette with a stock 350, 8-1 compression ratio.I have been told by JEGS that it is bolt on with no mods,however several people tell me that I have to change the cam,and the heads. So any advice you have i would apreicate.[/quote:a810c581ef]without bigger cam,higher flowing heads,and larger exhaust; it will be an overkill to go with a dual quad set-up.with a low 8:1 compression ratio,you would be better off with a supercharger.
Sep 30, 2007 at 12:56 PM
