On my 1978 Corvette, with 38000 miles, L82 engine, I have no brake pedal (goes to the floor).
With the Master Cylinder cap off, as I pump the brake pedal, I can see what appears to be "air bubbles". Both the primary and secondary master cylinder wells are 100% full. There is no obvious brake fluid on my garage floor.
The car is started and run about once a month for about 30 minutes (about 250 miles a year)
Is the possible that the Power Brake Booster Check Value is the problem?
Any suggestions?
Thanks,
Tom
Any suggestions?
Thanks,
Tom
Nov 24, 2007 at 6:17 AM
