2000 Chevy Corvette Tapping coming from the engine?
2000 CHEVROLET CORVETTE
26,600 MILES • V8 • 2WD • AUTOMATIC
CHARLESB1979
Hello! I own a 2000 Chevy Corvette Coupe with 26,600/mi. When I turn on my engine, I notice that there's a light tapping coming from the engine. I guess the easiest way for me to explain it, is that the engine somewhat sounds the same as that of a School Bus engine (not as loud, but it definitely reminds me of that). The engine oil is new. I've heard that it could be a loose rocker arm, but i've been able to rule that out...another person said it could be a dirt issue within the engine...i'm just not sure, but it's a light tapping while the engine is cold - somewhat cold (cold start to about 160 degrees). I hope i've given enough information. It's the stock LS1 5.7L V8 engine.
Feb 16, 2008 at 11:53 PM
DENNYP
  • 1,824 POSTS
It could be a partially collapsed lifter. With the pushrods removed, the lifter plungers should be fully extended.
Feb 18, 2008 at 7:34 PM
CHARLESB1979
Thanks for your response...if it is a collapsed lifter, what should I do?
Feb 18, 2008 at 11:08 PM
DENNYP
  • 1,824 POSTS
Replace the lifter.
Feb 19, 2008 at 7:00 AM
CHARLESB1979
Okay! Any idea on costs? :)
Feb 19, 2008 at 9:48 AM
DENNYP
  • 1,824 POSTS
you will need to call around in your area, but the repair probably won't be cheap.
Feb 19, 2008 at 10:23 PM
