2000 Chevy Corvette HVAC fan not operating
2000 CHEVROLET CORVETTE
40,000 MILES • V8 • 2WD • AUTOMATIC
BANDC144
Replaced burnt 60amp fuse. the other 2 10 amp fuses OK. So is new 60 amp fuse. Fan not working. Likely causes? Is fan motor located under dash, in the center?
Jul 22, 2010 at 3:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty blower motor relay. if fuses and relay are good then the blower motor may be bad or wiring to fan is bad (cause of fuse burning in first place). the blower motor is under the right side of the dash, closer to passenger side than it is middle.
Jul 23, 2010 at 12:51 AM
BANDC144
thanks blue...I'll check it out
Jul 23, 2010 at 7:41 AM
