1999 Chevy Corvette HAZARD/TURN SIGNAL FLASHER WIRING HARNE
1999 CHEVROLET CORVETTE
35,000 MILES • V8 • 2WD • AUTOMATIC
DENNIS COLTART
My Vette keeps burning out the right side turn signal/hazard light. Upon viewing the light socket, it looks like it got too hot and burned the connection at the light bulb end. I suspect that I need a new 'harness'. I'd like to install a new one myself. Can you explain the procedure for doing that? Is it a simple process or should I take it to a dealership to install?
Thanks for the help!
May 18, 2010 at 11:56 AM
HMAC300
  • 48,601 POSTS
first go to an auto parts store and see if you can get the socket. If you can usually they have wires attached to them. Then cut and strip the wires on both ends and put on connectors, then make sure they are connected well. get some shrink tube and put over the repaired area. put eh bul in and put teh socket back in.......
Jun 12, 2010 at 1:20 PM
