1998 Corvette - front light and turn signal replacement
1998 CHEVROLET CORVETTE
DAL_HORN
1998 Corvette - 71,000 miles/350 Auto: I have one turn signal bulb that is out. I have figured out how to change that. But, I also have the bulb between the turn signal and the fog lamp out and i dont know how to change that. Are there any tricks to this process? It is a tight squeeze to get my arm down there but i am able to. Any help would be greatly appreciated.
Jul 7, 2007 at 12:22 PM
STRAIGHT AHEAD
  • 41 POSTS
Best guess. You can use a long nose needle pylers. But first disconnect the battery. That bulb is a hot bulb. High intensity. Once you get it out and replace it. Do NOT! Touch the glass with you hand. Oils from your hand will make it fail Good luck
Jul 22, 2007 at 10:25 PM
