1998 Chevy Corvette need help
1998 CHEVROLET CORVETTE
123,000 MILES • V8 • 2WD • AUTOMATIC
DSAUTO
i have a 98 corvette with dual climate controle. when ac is on it blows cold on passenger side vents and hot on drivers side vents. ive replaced the head unit and still does same thing. any help i can get will b appreciated
Sep 22, 2010 at 1:27 PM
WRENCHTECH
  • 20,761 POSTS
First thing to check is the exact refrigerant charge. You can't rely on the pressures and they have been known to act that way being as little as a couple ounces low on refrigerant.
If that checks out OK, then you probably have a problem with the blend door actuator or the blend door itself on that side of the system. If you can access the actuator, see if it is trying to respond when the temp setting is changing.
Sep 22, 2010 at 1:39 PM
