I am having a problem starting my 95 vet it turns over healthy will start for second or two w/ starting fliuid seeems to be fuel related. Don't hear fuel pump, removed rubber tank fill collar, seperated wire plug to test voltage going to fuel pump I get 12 volts on one terminal [purple wire] with key on or off, seems like I should get voltage at least on one more lead when key is on Don't want to pull out fuel pump until I'm sure it's bad Would like any other advice for testing pump. Appreciate it greatly
Aug 27, 2008 at 10:36 AM
