1994 Chevy Corvette Drivers side window
1994 CHEVROLET CORVETTE
55,000 MILES • V8 • 2WD • AUTOMATIC
BOOTHK68
The drivers side window does not operate. It has a duel switch and the the one for the passenger side still operates that window.
Feb 26, 2010 at 2:35 PM
TOOOMANYTOYS
  • 513 POSTS
Remove the driver side door panel. Remove the connector going to window motor. Place a test light to the connector move the window switch if it light up in both positions it most likely needs a window motor. You can also try tapping the window motor and see if it tries to work.
Feb 26, 2010 at 2:40 PM
